Aller au contenu principal
Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront les 2 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 1
Étape 1
After removing the front and rear panels, locate the viewfinder directly above the lens on top of the camera.
  • After removing the front and rear panels, locate the viewfinder directly above the lens on top of the camera.
  • Three screws hold the viewfinder in place: two on the top and one on the lens side of the camera.
  • First, remove the screw in the bent corner of the viewfinder with a Phillips #00 screwdriver.
Après avoir retiré les panneaux avant et arrière, placez le viseur directement au-dessus de l'objectif sur le dessus de l'appareil photo.
Trois vis maintiennent le viseur en place. Deux sur le dessus et un sur le côté objectif de l'appareil photo.
Tout d'abord, retirez la vis dans le coin courbé du viseur.
[* black] After removing the front and rear panels, locate the viewfinder directly above the lens on top of the camera.
-[* black] Three screws hold the viewfinder in place. Two on the top and one on the lens side of the camera.
-[* yellow] First, remove the screw in the bent corner of the viewfinder.
+[* black] Three screws hold the viewfinder in place: two on the top and one on the lens side of the camera.
+[* red] First, remove the screw in the bent corner of the viewfinder with a Phillips #00 screwdriver.
