Aller au contenu principal
Anglais
Français
Traduction de l’étape 3
Étape 3
Remove the lower 10mm nut on your engine shocks so the shock can move up as you jack up the engine. In order to loosen this nut you will need to keep the shaft on the bottom of the engine shock from turning with it.
  • Remove the lower 10mm nut on your engine shocks so the shock can move up as you jack up the engine.
  • In order to loosen this nut you will need to keep the shaft on the bottom of the engine shock from turning with it.
  • Just above the large metal washer on the shaft there is a flat area where a 7mm crescent wrench will fit on the shaft to hold it. It can be seen in this picture from above the car.
Insérez ici votre traduction
