Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Anglais
Français
Traduction de l’étape 1
Étape 1
In order to proceed with the removal of your engine shocks you will need to remove the large lower bolts that hold the engine to the motor mounts, and then jack up the engine enough to allow for the removal of the shocks. For more on this, see the motor mount replacement guide. Since you will be removing one half of the bolts that hold your motor mounts in place consider replacing the mounts while you're replacing the shocks if you feel they are worn. These jobs are best done together.
  • In order to proceed with the removal of your engine shocks you will need to remove the large lower bolts that hold the engine to the motor mounts, and then jack up the engine enough to allow for the removal of the shocks.
  • For more on this, see the motor mount replacement guide.
  • Since you will be removing one half of the bolts that hold your motor mounts in place consider replacing the mounts while you're replacing the shocks if you feel they are worn. These jobs are best done together.
Insérez ici votre traduction
