Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Anglais
Français
Traduction de l’étape 3
Étape 3
Remove the 10mm nut on the bottom of the shock. Note that if you try to remove this nut you cannot at first as the shaft on the shock turns along with it.
  • Remove the 10mm nut on the bottom of the shock.
  • Note that if you try to remove this nut you cannot at first as the shaft on the shock turns along with it.
  • There is a flat area on the shaft, just above the large metal washer on the bottom portion of the shock. Place a 7mm crescent wrench on this to prevent the shaft from spinning. Pictured from above.
Insérez ici votre traduction
