Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Anglais
Français
Traduction de l’étape 5
Étape 5
Make note of the order of the bushings, washers and cups as you remove them.
  • Make note of the order of the bushings, washers and cups as you remove them.
  • Shown here is the order, from bottom on the right to top on the left. On the bottom the mount on the cross member goes between each rubber bushing. On the top, the bracket goes between the rubber bushings.
  • Consider replacing the rubber bushings while you are replacing the shock. With age they soften and compress becoming less effective. New bushings are shown in this picture.
  • Remember that the shock shaft that has the flat spot for the 7mm wrench goes on the bottom.
Insérez ici votre traduction
