Aller au contenu principal
Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront le tutoriel qui comprend ces étapes.
Anglais
Français
Traduction de l’étape 5
Étape 5
Continue sewing through both layers, going down from the top and up from the bottom, as described in steps 3 and 4 of this guide. When you come to the end of your material, draw the needle in between the two layers of material, under the thread of the closest stitch. Slowly start to pull the thread taut. As you pull a loop will form.
  • Continue sewing through both layers, going down from the top and up from the bottom, as described in steps 3 and 4 of this guide.
  • When you come to the end of your material, draw the needle in between the two layers of material, under the thread of the closest stitch.
  • Slowly start to pull the thread taut. As you pull a loop will form.
  • Draw the needle through the loop and pull the thread taut.
  • Repeat the process of drawing the needle between the layers, creating a loop, and drawing the needle through the loop as described in this step.
Insérez ici votre traduction
