Aller au contenu principal
Nikon D70 Top Cover Replacement
Info : Vous modifiez actuellement une condition préalable du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 2 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 3
Étape 3
Nikon D70 Top Cover Replacement: étape 0, image 1 de 3 Nikon D70 Top Cover Replacement: étape 0, image 2 de 3 Nikon D70 Top Cover Replacement: étape 0, image 3 de 3
  • Carefully de-solder the black, grey, white, and orange leads (boxed in red) from the side of the circuit board near the AF lamp.
  • Lightly heat the joint of each lead with a soldering iron as you apply slight tension to the wire with a pair of tweezers.
  • Do not excessively heat the board. Also, be sure not to accidentally melt the plastic case with the side of the soldering iron.
  • Repeat the process until all four leads are de-soldered.
Insérez ici votre traduction
