Aller au contenu principal
Anglais
Français
Traduction de l’étape 7
Étape 7
The VideoRAM/SGRAM slot is located between the video/sound card and the ROM slot. Part A: Place the SGRAM in to the slot at an angle.  Do not force the SGRAM in.  If you are gentle the SGRAM will slide down into the slot and sit at an angle. Part B: GENTLY Apply pressure to the corners of the SGRAM until it lies flat in the slot.  The white slot has small clips that will "lock" the SGRAM in place.  You may hear small clicks when the SGRAM is locked in place.
Installing VideoRAM/SGRAM
  • The VideoRAM/SGRAM slot is located between the video/sound card and the ROM slot.
  • Part A: Place the SGRAM in to the slot at an angle. Do not force the SGRAM in. If you are gentle the SGRAM will slide down into the slot and sit at an angle.
  • Part B: GENTLY Apply pressure to the corners of the SGRAM until it lies flat in the slot. The white slot has small clips that will "lock" the SGRAM in place. You may hear small clicks when the SGRAM is locked in place.
Insérez ici votre traduction
