Aller au contenu principal
Anglais
Français
Traduction de l’étape 9
Étape 9
With some fluid removed and the top left off of the brake fluid reservoir, use a large pry tool to gently pry the pistons back in to the body of the caliper.
  • With some fluid removed and the top left off of the brake fluid reservoir, use a large pry tool to gently pry the pistons back in to the body of the caliper.
  • Always use the flat surface of the pry, never the tip, and try to push the piston back in as straight and evenly as possible.
  • Alternately, you can purchase the proper brake caliper piston compression tool from Mercedes...but this pry bar technique works if you are careful.
  • Repeat this on all four pistons. Watch the brake fluid level as your proceed to ensure it does not overflow the reservoir. Remove more if necessary.
Insérez ici votre traduction
