Aller au contenu principal
Anglais
Français
Traduction de l’étape 1
Étape 1
You will need to remove your wheels before you start. Before beginning on removal of the calipers you should drain the brake fluid from them.
Drain the brake fluid
  • You will need to remove your wheels before you start.
  • Before beginning on removal of the calipers you should drain the brake fluid from them.
  • This is done through the bleed screw on each caliper.
  • Loosen this and let it drain in to a proper drain pan.
Insérez ici votre traduction
