Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Anglais
Français
Traduction de l’étape 3
Étape 3
Use a fine grit sandpaper, and optionally a power sander, to work around the flat surface of the hub to remove rust. Then use the sandpaper to remove rust from the raised portion at the center of the hub. The area around the lug bolt holes is recessed slightly and does not contact the rotors so it does not to be fully de-rusted.
Clean the hub surface
  • Use a fine grit sandpaper, and optionally a power sander, to work around the flat surface of the hub to remove rust.
  • Then use the sandpaper to remove rust from the raised portion at the center of the hub.
  • The area around the lug bolt holes is recessed slightly and does not contact the rotors so it does not to be fully de-rusted.
  • Spray the hub down with brake cleaner to remove the dust.
Insérez ici votre traduction
