Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Anglais
Français
Traduction de l’étape 6
Étape 6
While it is still inserted between the metal LCD frame and the front bezel, run the edge of your metal spudger along the top edge of the display to separate the adhesive securing the two pieces together, heating the area you are working on with a heat gun as necessary.
  • While it is still inserted between the metal LCD frame and the front bezel, run the edge of your metal spudger along the top edge of the display to separate the adhesive securing the two pieces together, heating the area you are working on with a heat gun as necessary.
  • If the adhesive is hard to separate, use a heat gun to lightly heat the area you are working on.
Insérez ici votre traduction
