Aller au contenu principal
Info : Vous modifiez un tutoriel pré-requis. Toutes les modifications apportées affecteront le tutoriel qui comprend ces étapes.
Anglais
Français
Traduction de l’étape 4
Étape 4
Join the lead leaving the resistor to the stripped end of the wire by twisting the two together. The wire we are using is quite thick, so we inserted the resistor lead down the center of the conductor portion of the wire and twisted the wire against it as tightly as possible. Solder the wire to the resistor.
  • Join the lead leaving the resistor to the stripped end of the wire by twisting the two together.
  • The wire we are using is quite thick, so we inserted the resistor lead down the center of the conductor portion of the wire and twisted the wire against it as tightly as possible.
  • Solder the wire to the resistor.
  • It is essential that enough solder flows through the wire to create a permanent bond between the two pieces.
Insérez ici votre traduction
