Aller au contenu principal
Info : Vous modifiez un tutoriel pré-requis. Toutes les modifications apportées affecteront les tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 8
Étape 8
When removing the coil, make sure it stays wound up.  It could very easily pop out, and you would have to wind it all the way back up and try to squeeze it back into the slot when you reassemble the dryer. To remove the coil, use your screw driver to pop the coil out of the slot.
  • When removing the coil, make sure it stays wound up. It could very easily pop out, and you would have to wind it all the way back up and try to squeeze it back into the slot when you reassemble the dryer.
  • To remove the coil, use your screw driver to pop the coil out of the slot.
  • This is what the coil would look like if it came undone when you removed it.
Insérez ici votre traduction
