Aller au contenu principal
Anglais
Français
Traduction de l’étape 7
Étape 7
Now that the motherboard is out, this is the screen/digitizer/LCD assembly. From here, we need to only remove the digitizer. We recommend using a heat gun or a hot plate if you have one. If you don't have either, use a blow dryer! We recommend using a heat gun or a hot plate if you have one. If you don't have either, use a blow dryer!
  • Now that the motherboard is out, this is the screen/digitizer/LCD assembly. From here, we need to only remove the digitizer.
  • We recommend using a heat gun or a hot plate if you have one. If you don't have either, use a blow dryer!
Insérez ici votre traduction
