Aller au contenu principal
Anglais
Français
Traduction de l’étape 1
Étape 1
Before you start make sure that all of the leads have been disconnected from the computer. It is strongly recommended that you leave the computer off for at least 15 minutes to allow the components to cool down. You should also ground yourself before starting by using an anti-static band or touching a metal object connected to the ground. This prevents static build up which can destroy sensitive components.
  • Before you start make sure that all of the leads have been disconnected from the computer.
  • It is strongly recommended that you leave the computer off for at least 15 minutes to allow the components to cool down.
  • You should also ground yourself before starting by using an anti-static band or touching a metal object connected to the ground. This prevents static build up which can destroy sensitive components.
Insérez ici votre traduction
