Aller au contenu principal
Anglais
Français
Traduction de l’étape 6
Étape 6
You now need to remove the power cable connected to the motherboard. Locate the large 24 pin power connecter - it is located next to the power supply. Carefully press down on the little latch and pull straight up to release. Repeat this procedure for the little 4 pin connecter located between the processer and hard drive.
  • You now need to remove the power cable connected to the motherboard.
  • Locate the large 24 pin power connecter - it is located next to the power supply. Carefully press down on the little latch and pull straight up to release.
  • Repeat this procedure for the little 4 pin connecter located between the processer and hard drive.
Insérez ici votre traduction
