Aller au contenu principal
Info : Vous modifiez un tutoriel pré-requis. Toutes les modifications apportées affecteront les tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 2
Étape 2
Simply remove the bottom panel by prying it off with your finger. When removing the panel, be sure the bottom of the camera is facing upright.  There are loose gears that may fall out. Be wary of a loose piece of foam attached to the bottom panel.
  • Simply remove the bottom panel by prying it off with your finger.
  • When removing the panel, be sure the bottom of the camera is facing upright. There are loose gears that may fall out.
  • Be wary of a loose piece of foam attached to the bottom panel.
Insérez ici votre traduction
