Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Anglais
Français
Traduction de l’étape 1
Étape 1
In the following steps you will use a heat gun to soften the adhesive securing the black plastic frame to the front glass. Do not allow the stream of hot air to contact the thin rubber strip around the outer perimeter of the front glass as it may melt, permanently deform, and lose texture.
  • In the following steps you will use a heat gun to soften the adhesive securing the black plastic frame to the front glass. Do not allow the stream of hot air to contact the thin rubber strip around the outer perimeter of the front glass as it may melt, permanently deform, and lose texture.
  • Use a heat gun to gently heat the plastic display frame near the home button from the inner side of the front glass panel.
Insérez ici votre traduction
