Aller au contenu principal
Fix Your Stuff
Right to Repair
Parts & Tools
Info : Vous modifiez actuellement un prérequis du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 32 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 8
Étape 8
Do not try to completely remove the front panel assembly from the rear case, as there are several delicate ribbon cables connecting them. Pull the plastic nub to release the vacuum seal on the suction cup.
  • Do not try to completely remove the front panel assembly from the rear case, as there are several delicate ribbon cables connecting them.
  • Pull the plastic nub to release the vacuum seal on the suction cup.
  • Remove the suction cup from the screen.
N'essayez pas de retirer complètement l'écran du boîtier arrière car plusieurs câbles plats délicats les relient encore.
Tirez sur la petite bosse en plastique pour libérer l'air dans la ventouse.
Enlevez la ventouse de l'écran.
[* icon_caution] Do not try to completely remove the front panel assembly from the rear case, as there are several delicate ribbon cables connecting them.
[* black] Pull the plastic nub to release the vacuum seal on the suction cup.
[* black] Remove the suction cup from the display assemblyscreen.
