Aller au contenu principal
Remplacement de la caméra avant et de la nappe de capteur de l'iPhone 5s
Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront le tutoriel qui comprend ces étapes.
Traduction de l’étape 4
Anglais
Français
Étape 4
iPhone 5s Front Facing Camera and Sensor Cable  Replacement: étape 0, image 1 de 3 iPhone 5s Front Facing Camera and Sensor Cable  Replacement: étape 0, image 2 de 3 iPhone 5s Front Facing Camera and Sensor Cable  Replacement: étape 0, image 3 de 3
  • If your replacement sensor cable has an extra tab, you'll need to carefully cut it off. You won't need this tab—it's used for parts testing.
  • Use scissors to cut the cable right below the yellow plastic tabs.
Insérez ici votre traduction
+[* icon_note] If your replacement sensor cable has an extra tab, you'll need to carefully cut it off. You won't need this tab—it's used for parts testing.
+ [* red] Use scissors to cut the cable right below the yellow plastic tabs.
