Info : Vous modifiez actuellement une condition préalable du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 7 tutoriels qui comprennent cette étape.
Traduction de l’étape 6
Étape 6
Remove the following screws from the logic board:
One 2.4 mm Phillips #000 screw
Two 2.3 mm Phillips #000 screws
Four 2.8 mm standoff screws
[* black] Remove the following screws from the logic board: |
[* red] One 2.4 mm Phillips #000 screw |
[* icon_reminder] This screw also holds a small metal contact beneath the logic board. It's held in place underneath a plastic bracket, but if you see it slipping out, refer to [guide|20246|this step|stepid=72613|new_window=true] to remove it. |
[* orange] Two 2.3 mm Phillips #000 screws |
[* yellow] Four 2.8 mm standoff screws |
[* icon_note] Standoff screws are best removed using |
[* icon_caution] In a pinch, a small flathead screwdriver will do the job—but use extra caution to ensure it doesn't slip and damage surrounding components. |
