Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Info : Vous modifiez actuellement un prérequis du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 5 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 4
Étape 4
Guide the strip carefully around the corner and up the side of the battery. Be careful not to snag it on the corner of the battery or on any of the other internal iPhone components. The strip will stretch to many times its original length. Continue pulling, re-grabbing the strip near the battery if necessary, until the entire strip comes free.
  • Guide the strip carefully around the corner and up the side of the battery.
  • Be careful not to snag it on the corner of the battery or on any of the other internal iPhone components.
  • The strip will stretch to many times its original length. Continue pulling, re-grabbing the strip near the battery if necessary, until the entire strip comes free.
Tirez la patte soigneusement et uniformément autour du coin de la batterie.
Tirez la patte loin de la batterie en passant autour de l'angle de la batterie pour éviter le coin pointu.
Tirez la bande le long de la batterie jusqu'à ce que la bande se libère du téléphone.
[* black] PullGuide the tabstrip carefully and evenly around the corner and up the side of the battery.
[* icon_note] Pull
[* icon_caution] Be careful not to snag it on
the tab away fromcorner of the battery as you roundor on any of the corner to avoid the sharp cornerother internal iPhone components.
[* black] Pullicon_note] The strip will stretch to many times its original length. Continue pulling, re-grabbing the strip along the side ofnear the battery if necessary, until the entire strip comes free from the phonefree.
[* icon_note] Pull
