Aller au contenu principal
Anglais
Français
Traduction de l’étape 9
Étape 9
After re-inserting the ribbon cables a small one for the buttons at the front of the bezel and the main one that carries the data to the display, once you have reconnected successfully you should get a clean bouncing screen saver moving around the screen, if there are any screen anomalies it is always the thicker data cable that needs reseating
This is what a successfully repaired monitor should look like
  • After re-inserting the ribbon cables a small one for the buttons at the front of the bezel and the main one that carries the data to the display, once you have reconnected successfully you should get a clean bouncing screen saver moving around the screen, if there are any screen anomalies it is always the thicker data cable that needs reseating
Insérez ici votre traduction
