Aller au contenu principal
Anglais
Français
Traduction de l’étape 10
Étape 10
it's best to test the monitor before you put the back cover on the screen, as invariably the larger of the two ribbon cables has not seated correctly, once you're happy your screen works put everything back together and you're good to go it's best to test the monitor before you put the back cover on the screen, as invariably the larger of the two ribbon cables has not seated correctly, once you're happy your screen works put everything back together and you're good to go it's best to test the monitor before you put the back cover on the screen, as invariably the larger of the two ribbon cables has not seated correctly, once you're happy your screen works put everything back together and you're good to go
Put the back cover back on
  • it's best to test the monitor before you put the back cover on the screen, as invariably the larger of the two ribbon cables has not seated correctly, once you're happy your screen works put everything back together and you're good to go
Insérez ici votre traduction
