Aller au contenu principal
Info : Vous modifiez un tutoriel pré-requis. Toutes les modifications apportées affecteront les tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 2
Étape 2
Grab the lifted edge of the fuse between your thumb and forefinger and pull it the rest of the way out of the device.
  • Grab the lifted edge of the fuse between your thumb and forefinger and pull it the rest of the way out of the device.
  • The fuse in the upper left corner can be tricky to remove. Use a plastic opening tool if needed.
  • Repeat steps 4 and 5 to remove the other fuse if you are replacing both fuses or if you are replacing a different part further on.
Insérez ici votre traduction
