Aller au contenu principal
Info : Vous modifiez actuellement un pré-requis du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 5 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 1
Étape 1
Detach the motherboard ribbon connecting the two sides of the controller by pulling it straight out with your fingers. Note the orientation of the cable and make sure it faces the right way when you reconnect it. After the two halves are separated, place the top of the controller off to the side.
  • Detach the motherboard ribbon connecting the two sides of the controller by pulling it straight out with your fingers.
  • Note the orientation of the cable and make sure it faces the right way when you reconnect it.
  • After the two halves are separated, place the top of the controller off to the side.
Détachez la nappe de la carte mère, qui relie les deux côtés de la manette, en utilisant vos doigts.
Une fois les deux moitiés séparées, mettez la partie supérieure de la manette de côté.
[* black] Detach the motherboard ribbon connecting the two sides of the controller by usingpulling it straight out with your fingers.
[* icon_reminder] Note the orientation of the cable and make sure it faces the right way when you reconnect it.
[* black] After the two halves are separated, place the top of the controller off to the side.
