Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront les 2 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 4
Étape 4
Use the spudger to disconnect the ribbon cable from the display by the black pins away from the connector. There is a pin on either side of the connector. Once both pins are released, the ribbon cable should slide easily out. It may be easier if someone else holds the display so the cable does not get ripped out.
  • Use the spudger to disconnect the ribbon cable from the display by the black pins away from the connector. There is a pin on either side of the connector.
  • Once both pins are released, the ribbon cable should slide easily out.
  • It may be easier if someone else holds the display so the cable does not get ripped out.
Insérez ici votre traduction
