Aller au contenu principal
Info : Vous modifiez un tutoriel pré-requis. Toutes les modifications apportées affecteront le tutoriel qui comprend ces étapes.
Anglais
Français
Traduction de l’étape 1
Étape 1
Using a Torx-Security T-15 screw driver, loosen the screws a little at a time evenly on each screw (process described below): This process is done by slightly unscrewing a screw at one corner and moving to the screw at the diagonal corner next to unscrew slightly.
  • Using a Torx-Security T-15 screw driver, loosen the screws a little at a time evenly on each screw (process described below):
  • This process is done by slightly unscrewing a screw at one corner and moving to the screw at the diagonal corner next to unscrew slightly.
  • Then move to the opposite corners and repeat the process.
  • Continue until all of the screw are completely removed.
  • Remember to loosen opposite corners first to equalize the pressure on the springs. Do not completely unscrew one screw at one time. Unscrew each screw a little at a time.
Insérez ici votre traduction
