Aller au contenu principal
Info : Vous modifiez actuellement un pré-requis du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 4 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 2
Étape 2
Remove the two cables on the motherboard by grasping the cables with your hand and pulling the cables up and out.
  • Remove the two cables on the motherboard by grasping the cables with your hand and pulling the cables up and out.
  • Repeat the same process to remove the internal card power cable.
  • This is the same process as preformed when you previously removed the power cables from the optical drive and the hard drive.
  • Some cables may have small clips securing them in place. If so, be sure to press these clips inward using your fingers before pulling them out.
Insérez ici votre traduction
