Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Anglais
Français
Traduction de l’étape 3
Étape 3
This job is being documented with the thermostat housing removed from the engine. However, it can normally be done with it still installed.
  • This job is being documented with the thermostat housing removed from the engine. However, it can normally be done with it still installed.
  • To help orient you to the housing, here are the various components:
  • Neck for line to top of radiator, upper radiator hose connection. This is the TOP of the housing.
  • Neck for line to bottom of radiator, lower radiator hose.
  • Neck to short coolant hose under the housing, for water pump bypass.
  • If you'd like to remove the housing to complete this job you can review the process in the [lien de tutoriel non valide]
Insérez ici votre traduction
