Aller au contenu principal
ChefsChoice M677 Power Supply Replacement
Info : Vous modifiez actuellement une condition préalable du tutoriel que vous venez de consulter. Toutes les modifications affecteront le tutoriel qui comprend cette étape.
Anglais
Français
Traduction de l’étape 5
Étape 5
ChefsChoice M677 Power Supply Replacement: étape 0, image 1 de 3 ChefsChoice M677 Power Supply Replacement: étape 0, image 2 de 3 ChefsChoice M677 Power Supply Replacement: étape 0, image 3 de 3
  • Take note of how the wires connect to the components to aid reassembly.
  • Remove the connectors (spaded lugs) from the circuit components as shown in the second image.
  • DO NOT pull on the wires, as you might pull them out of the connectors.
  • You should be able to remove each connector easily by hand. Pinch the lug between your fingers and pull in the direction of the attached wire.
  • If necessary, use needle-nose pliers to grasp the lug shank firmly. Gently pull the lug in the direction of the attached wire.
  • Gently bend the disconnected wires back and out of the work area.
Insérez ici votre traduction
