Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront le tutoriel qui comprend ces étapes.
Anglais
Français
Traduction de l’étape 32
Étape 32
Starting in the optical drive area, slide the plastic opening tool under the top cover, prying up each side to loosen it from the computer. Remove the screw attaching the cover to the system board. The screw is 4 mm long and the head is 5 mm wide.
  • Starting in the optical drive area, slide the plastic opening tool under the top cover, prying up each side to loosen it from the computer.
  • Remove the screw attaching the cover to the system board.
  • The screw is 4 mm long and the head is 5 mm wide.
  • If you are having a hard time removing the cover, turn the computer over to ensure you removed all screws as mentioned in previous steps.
Insérez ici votre traduction
