Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Anglais
Français
Traduction de l’étape 2
Étape 2
With a plastic tool separate the frame from the aluminum plate. (either from the inside or outside) Make sure your Micro SD card is removed from the device Micro SD card slot. Disconnect the microphone using your fingers, be careful not to do too much pressure.
  • With a plastic tool separate the frame from the aluminum plate. (either from the inside or outside)
  • Make sure your Micro SD card is removed from the device Micro SD card slot.
  • Disconnect the microphone using your fingers, be careful not to do too much pressure.
Insérez ici votre traduction
