Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Anglais
Français
Traduction de l’étape 8
Étape 8
Rest the soldering iron on the battery pad to heat it up. Once the pad is hot enough, begin adding solder. If solder does not flow immediately when it comes in contact with the pad, remove it and allow the pad to heat up longer.
First melts
  • Rest the soldering iron on the battery pad to heat it up.
  • Once the pad is hot enough, begin adding solder.
  • If solder does not flow immediately when it comes in contact with the pad, remove it and allow the pad to heat up longer.
  • Apply a large gob of solder to the pad (as shown).
  • Tin the iron and return it to its stand.
Insérez ici votre traduction
