Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Anglais
Français
Traduction de l’étape 17
Étape 17
LEDs are polarized: one side of the diode is positive, the other is negative. It is typical convention for an LED to be manufactured with its positive lead longer than the negative lead. Positive lead (longer) Negative lead (shorter)
Position the LEDs
  • LEDs are polarized: one side of the diode is positive, the other is negative. It is typical convention for an LED to be manufactured with its positive lead longer than the negative lead.
  • Positive lead (longer)
  • Negative lead (shorter)
  • Insert the LED into the PCB as illustrated. Be sure to match up the positive lead of the LED (the longer one) with the positive pad on the PCB (marked with a "+").
  • Bend one of the leads down tightly. This serves as a securement so the part doesn't fall away while you solder.
Insérez ici votre traduction
