Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Anglais
Français
Traduction de l’étape 9
Étape 9
Desoldering tools are great for cleaning up mistakes. They're really easy to use! Apply a copious amount of solder to the battery pad, as explained in the previous step. [photo with copious solder, iron, and desoldering tool in play] Depress the plunger in the desoldering tool until it clicks.
Familiarize yourself with a desoldering tool
  • Desoldering tools are great for cleaning up mistakes. They're really easy to use!
  • Apply a copious amount of solder to the battery pad, as explained in the previous step. [photo with copious solder, iron, and desoldering tool in play]
  • Depress the plunger in the desoldering tool until it clicks.
  • Heat up the joint until the solder flows.
  • Press the tip of the desoldering tool into the pool of solder. Simultaneously press the return button on the tool.
  • Whoop! Away goes the solder! Press the plunger down again to release the solder it collected. [photo with iron and desoldering tool in play, solder gone]
  • If at any point in this tutorial you make a mistake, just remove the solder from the joint with this method and start that step over.
Insérez ici votre traduction
