Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Anglais
Français
Traduction de l’étape 3
Étape 3
Once the solder connection has heated up, apply slight tension to the ribbon cable which will allow for complete removal of the LED screen. Once the solder connection has heated up, apply slight tension to the ribbon cable which will allow for complete removal of the LED screen.
Remove the display
  • Once the solder connection has heated up, apply slight tension to the ribbon cable which will allow for complete removal of the LED screen.
Une fois que la pointe du fer à souder a chauffé, appliquer une légère tension sur le câble plat qui permettra le retrait complet de l'écran LED
[*title] Remove the display
black] Once the solder connection has heated upup, apply slight tension to the ribbon cable which will allow for complete removal of the LED screenscreen.
