Aller au contenu principal
Info : Vous modifiez actuellement un pré-requis du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 2 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 15
Étape 15
Set the display back on the iMac's rear enclosure. At this time, plug in your iMac, power it on, and test your repair before moving on to actually sealing up the computer. Be sure to check for full functionality of any hardware you removed or disconnected.
  • Set the display back on the iMac's rear enclosure.
  • At this time, plug in your iMac, power it on, and test your repair before moving on to actually sealing up the computer. Be sure to check for full functionality of any hardware you removed or disconnected.
  • When you are finished, shut the iMac down and unplug the power cord before you continue.
Décollez et enlevez les protections restantes de toutes les bandes autour de l´encadrement.
[* black] Peel upSet the display back on the iMac's rear enclosure.
[* icon_note] At this time, plug in your iMac, power it on,
and removetest your repair before moving on to actually sealing up the remaining backings from allcomputer. Be sure to check for full functionality of any hardware you removed or disconnected.
[* icon_caution] When you are finished, shut
the strips aroundiMac down and '''unplug the framepower cord''' before you continue.
