Aller au contenu principal
Info : Vous modifiez actuellement un pré-requis du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 2 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 16
Étape 16
Verify that your iMac is turned off and unplugged from power before you continue. After confirming that your iMac functions properly, disconnect the display cables and carefully lean the display forward.
  • Verify that your iMac is turned off and unplugged from power before you continue.
  • After confirming that your iMac functions properly, disconnect the display cables and carefully lean the display forward.
  • Remove the film from the 15 strip by reaching in from above and pulling the tab straight up from the bottom edge of the display.
Surtout ne pas abaisser complètement l'écran dans cette étape ; il restent encore deux câbles à attacher. Une fois que vous avez fixé l'écran vers le bas, vous ne serez pas en mesure de le soulever à nouveau sans endommager l'adhésif.
Poser le bord inférieur du verre de l'écran contre le haut du joint inférieur. Assurez-vous d'aligner les bords de l'écran avec les bords du boîtier arrière.
[* icon_caution] '''Do not '''fully lowerVerify that your iMac is turned off and unplugged from power before you continue.
[* black] After confirming that your iMac functions properly, disconnect
the display in this step; there are still two cables that must be attached. Once you've setand carefully lean the display down, you won't be able to lift it again without damaging the adhesiveforward.
[* black] LayRemove the bottom edge offilm from the display glass against15 strip by reaching in from above and pulling the top oftab straight up from the lower bezel. Be sure to align the edges of the display with the edgesbottom edge of the rear casedisplay.
