Aller au contenu principal
Info : Vous modifiez actuellement un pré-requis du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 2 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 19
Étape 19
Check the glass directly in front of the webcam for dust and other contaminants. If necessary, wipe it down with a microfiber cloth before you seal up the display. Steady the display with one hand as you remove the adhesive liners in the following steps, or rest it lightly against the iMac's enclosure. Steady the display with one hand as you remove the adhesive liners in the following steps, or rest it lightly against the iMac's enclosure.
  • Check the glass directly in front of the webcam for dust and other contaminants. If necessary, wipe it down with a microfiber cloth before you seal up the display.
  • Steady the display with one hand as you remove the adhesive liners in the following steps, or rest it lightly against the iMac's enclosure.
Avant de sceller l'écran en place, vous voudrez peut-être tester la mise sous tension de votre iMac pour vous assurer d' avoir tout reconnecté correctement. Faites attention à ne pas toucher quoi que ce soit à l'intérieur pendant que la machine est sous tension.
Tout en appuyant l'écran contre son rebord sur le panneau frontal inférieur, abaissez-le en place.
[* icon_caution] Before sealingicon_reminder] Check the screenglass directly in place, you may want to test powering on your iMac to ensurefront of the webcam for dust and other contaminants. If necessary, wipe it down with a microfiber cloth before you reconnected everything correctly. Be careful not to touch anything inside whileseal up the machine is powered ondisplay.
[* black] While pressingSteady the display against its ledge onwith one hand as you remove the lower bezel, loweradhesive liners in the following steps, or rest it down into placelightly against the iMac's enclosure.
