Aller au contenu principal
Info : Vous modifiez actuellement un pré-requis du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 2 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 2
Étape 2
Before you start placing strips, remove all of the old adhesive from around the perimeter of the rear enclosure. If you are re-using your existing display, you must also remove the old adhesive from the back of the display.
  • Before you start placing strips, remove all of the old adhesive from around the perimeter of the rear enclosure.
  • If you are re-using your existing display, you must also remove the old adhesive from the back of the display.
  • Peel off the old strips of adhesive using tweezers or your fingers. Start at the bottom and peel upward towards the top of the device.
  • After all the old adhesive is removed, carefully clean the area under the adhesive with 90% (or greater) isopropyl alcohol and a lint-free cloth. Wipe in one direction, not back and forth.
  • Don't skip this step, or your new adhesive strips may not bond properly, and the display may fall out of your iMac.
Avant de commencer à placer les nouvelles bandes, enlevez tout le vieil adhésif. Utilisez un spudger pour accrocher un bord, puis décollez avec vos doigts.
Retirez toutes les bandes adhésives restant sur le châssis de l'iMac et du verre de l'écran.
