Aller au contenu principal
Info : Vous modifiez un tutoriel pré-requis. Toutes les modifications apportées affecteront le tutoriel qui comprend ces étapes.
Anglais
Français
Traduction de l’étape 4
Étape 4
Insert the door panel pry tool into the notch found on the bottom of the door panel. Once fully inserted, pull towards you in order to disconnect the first retaining clip. The door panel should now be slightly looser on the bottom. Re-insert the pry tool on the bottom-right of the panel, and pull toward you to disconnect the second retaining clip.
  • Insert the door panel pry tool into the notch found on the bottom of the door panel.
  • Once fully inserted, pull towards you in order to disconnect the first retaining clip.
  • The door panel should now be slightly looser on the bottom. Re-insert the pry tool on the bottom-right of the panel, and pull toward you to disconnect the second retaining clip.
Insérez ici votre traduction
