Aller au contenu principal
Info : Vous modifiez actuellement un pré-requis du tutoriel que vous venez de consulter. Toutes les modifications affecteront le tutoriel% qui comprend cette étape.
Traduction de l’étape 1
Étape 1
Use a spudger or a flat-blade screwdriver to unlatch the plastic screw cover residing within the door pull handle. Move the plastic cover out of the way so that the Phillips screw is fully revealed. Use a #2 Phillips screwdriver to unscrew the screw residing underneath the plastic cover.
  • Use a spudger or a flat-blade screwdriver to unlatch the plastic screw cover residing within the door pull handle.
  • Move the plastic cover out of the way so that the Phillips screw is fully revealed.
  • Use a #2 Phillips screwdriver to unscrew the screw residing underneath the plastic cover.
Insérez ici votre traduction
