Aller au contenu principal
Info : Vous modifiez actuellement un pré-requis du tutoriel que vous venez de consulter. Toutes les modifications affecteront le tutoriel% qui comprend cette étape.
Traduction de l’étape 4
Étape 4
Insert the door panel pry tool into the notch found on the bottom of the door panel. Once fully inserted, pull towards you in order to disconnect the first retaining clip. The door panel should now be slightly looser on the bottom. Re-insert the pry tool on the bottom-right of the panel, and pull toward you to disconnect the second retaining clip.
  • Insert the door panel pry tool into the notch found on the bottom of the door panel.
  • Once fully inserted, pull towards you in order to disconnect the first retaining clip.
  • The door panel should now be slightly looser on the bottom. Re-insert the pry tool on the bottom-right of the panel, and pull toward you to disconnect the second retaining clip.
Insérez ici votre traduction
