Aller au contenu principal
Anglais
Français
Traduction de l’étape 1
Étape 1
The speaker is connected on the back with speaker wire, so do not yank it out of its housing once you remove the screws. Use a #2 Phillips screwdriver to unscrew the three Phillips retaining screws. Gently pull the speaker an inch or two from the door in order to expose the wire and connector on the back of the speaker.
  • The speaker is connected on the back with speaker wire, so do not yank it out of its housing once you remove the screws.
  • Use a #2 Phillips screwdriver to unscrew the three Phillips retaining screws.
  • Gently pull the speaker an inch or two from the door in order to expose the wire and connector on the back of the speaker.
Insérez ici votre traduction
