Aller au contenu principal
Anglais
Français
Traduction de l’étape 3
Étape 3
You can use aftermarket speaker harnesses instead of cutting the factory speaker connectors. Each set is usually $10+ and simplifies the process -- but then you have extra wires and connectors jiggling in the door. The steps below are the simpler, cheaper route.
  • You can use aftermarket speaker harnesses instead of cutting the factory speaker connectors. Each set is usually $10+ and simplifies the process -- but then you have extra wires and connectors jiggling in the door. The steps below are the simpler, cheaper route.
  • I also knew I would not ever return to the factory speakers, so this was a simple choice for me.
  • Use a pair of wire cutters to cut the factory speaker connector from the rest of the speaker wiring. Leave a bit of wire on the connector side, should you ever need to put it back onto the wires.
Insérez ici votre traduction
