Aller au contenu principal
Anglais
Français
Traduction de l’étape 10
Étape 10
Use a #2 Phillips screwdriver to hand tighten the top mounted screw. Do not use a drill or power driver for this task -- you'll have a bad time if you strip the hole. Use a #2 Phillips screwdriver to hand tighten the top mounted screw. Do not use a drill or power driver for this task -- you'll have a bad time if you strip the hole.
  • Use a #2 Phillips screwdriver to hand tighten the top mounted screw. Do not use a drill or power driver for this task -- you'll have a bad time if you strip the hole.
Insérez ici votre traduction
