Aller au contenu principal
Info : Vous modifiez actuellement un pré-requis du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 4 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 1
Étape 1
The first step is to remove the battery from the laptop. Use a plastic opening tool to pull up the four metal latches in the battery cavity that is located on the bottom of the laptop.
  • The first step is to remove the battery from the laptop.
  • Use a plastic opening tool to pull up the four metal latches in the battery cavity that is located on the bottom of the laptop.
  • Do not apply too much pressure. The latches can not be removed and will bend if forced.
Insérez ici votre traduction
