Aller au contenu principal
Anglais
Français
Traduction de l’étape 2
Étape 2
Peel skin off, but not all the way off, from ONE battery. Slice some skin off from the other. both sides. Until the black plastic PCB cover and be easily removed. Slice some skin off from the other. both sides. Until the black plastic PCB cover and be easily removed.
  • Peel skin off, but not all the way off, from ONE battery.
  • Slice some skin off from the other. both sides. Until the black plastic PCB cover and be easily removed.
Décollez le revêtement, mais pas complètement, D'UNE SEULE batterie.
Enlevez un peu de revêtement de l'autre batterie. Des deux côtés. Jusqu'à ce que le plastique noir couvrant le circuit imprimé (PCB) soit facile à retirer.
